martinw17 Posted April 24, 2012 Share Posted April 24, 2012 hi guys were have u guys threaded your sub power cable mine through door atm looks horrible so want to do it properly advice much appreciated thanks Link to comment Share on other sites More sharing options...
Stu Posted April 25, 2012 Share Posted April 25, 2012 Why would you put a power cable through a door?! Link to comment Share on other sites More sharing options...
martinw17 Posted April 25, 2012 Author Share Posted April 25, 2012 Why would you put a power cable through a door?!no i mean were the door closes near the wing Link to comment Share on other sites More sharing options...
Stu Posted April 25, 2012 Share Posted April 25, 2012 Just drill a hole behind the battery and use a proper grommet to feed the cable through. Link to comment Share on other sites More sharing options...
Naylor2006 Posted April 25, 2012 Share Posted April 25, 2012 Can always feed it down the whole in the wing mate thats next to the battery, thats were I put mine. I got an old coat hanger, the metal type, and worked it into the wing from the passenger footwell around the ECU. Then stuck my arm into the hole in the inside of the wing and grabbed it, tied the amp wire to it and then pulled it back through. Link to comment Share on other sites More sharing options...
martinw17 Posted April 25, 2012 Author Share Posted April 25, 2012 Can always feed it down the whole in the wing mate thats next to the battery, thats were I put mine. I got an old coat hanger, the metal type, and worked it into the wing from the passenger footwell around the ECU. Then stuck my arm into the hole in the inside of the wing and grabbed it, tied the amp wire to it and then pulled it back through.thanks mate will try it tomoz if its not peeing it down so i wont need to cut a hole then thanks Link to comment Share on other sites More sharing options...
martinw17 Posted April 26, 2012 Author Share Posted April 26, 2012 Can always feed it down the whole in the wing mate thats next to the battery, thats were I put mine. I got an old coat hanger, the metal type, and worked it into the wing from the passenger footwell around the ECU. Then stuck my arm into the hole in the inside of the wing and grabbed it, tied the amp wire to it and then pulled it back through.do u mean thread it through were the door closes n thead it through the wing thanks Link to comment Share on other sites More sharing options...
marshy Posted April 26, 2012 Share Posted April 26, 2012 theres a hole in the bulkhead youll have to find it that leads into the passeger cabin.. and as said grommet it feed the wire thro.. Link to comment Share on other sites More sharing options...
martinw17 Posted April 27, 2012 Author Share Posted April 27, 2012 theres a hole in the bulkhead youll have to find it that leads into the passeger cabin.. and as said grommet it feed the wire thro..oh yerr thanks wish this rain will stop so i have have a proper look n will dash have to come out thanks Link to comment Share on other sites More sharing options...
Naylor2006 Posted April 27, 2012 Share Posted April 27, 2012 Can always feed it down the whole in the wing mate thats next to the battery, thats were I put mine. I got an old coat hanger, the metal type, and worked it into the wing from the passenger footwell around the ECU. Then stuck my arm into the hole in the inside of the wing and grabbed it, tied the amp wire to it and then pulled it back through.do u mean thread it through were the door closes n thead it through the wing thanks I can't remember exactly but look at the battery then just to the right on the inner side of the wing yourll see a whole bunch of wires going in, the hole is about the size of a fist. From the footwell in I can't remember exactly but pull up the carpet and find your way in, it's near the ecu not the door where I went through. Link to comment Share on other sites More sharing options...
martinw17 Posted April 29, 2012 Author Share Posted April 29, 2012 Can always feed it down the whole in the wing mate thats next to the battery, thats were I put mine. I got an old coat hanger, the metal type, and worked it into the wing from the passenger footwell around the ECU. Then stuck my arm into the hole in the inside of the wing and grabbed it, tied the amp wire to it and then pulled it back through.do u mean thread it through were the door closes n thead it through the wing thanks I can't remember exactly but look at the battery then just to the right on the inner side of the wing yourll see a whole bunch of wires going in, the hole is about the size of a fist. From the footwell in I can't remember exactly but pull up the carpet and find your way in, it's near the ecu not the door where I went through.nice one mate thanks very much 4 explaining it for me will have a look later when finish work if not RAINING lol Link to comment Share on other sites More sharing options...
martinw17 Posted May 1, 2012 Author Share Posted May 1, 2012 done it now thanks lads x Link to comment Share on other sites More sharing options...
shawdreamer Posted May 2, 2012 Share Posted May 2, 2012 done it now thanks lads x awwww a "x"........... your in there Naylor. Link to comment Share on other sites More sharing options...
Naylor2006 Posted May 2, 2012 Share Posted May 2, 2012 done it now thanks lads x awwww a "x"........... your in there Naylor. lol, he said lads, that includes you now. Out of interest which did you go for in the end, which route? <----- no jokes please Shaw Link to comment Share on other sites More sharing options...
martinw17 Posted May 2, 2012 Author Share Posted May 2, 2012 done it now thanks lads x awwww a "x"........... your in there Naylor. lol, he said lads, that includes you now. Out of interest which did you go for in the end, which route? <----- no jokes please Shaw haha lol pmsl and i went through gromit just near glove box went through that and through hole in wing and to battery thanks Link to comment Share on other sites More sharing options...
