scottg17 Posted June 22, 2012 Share Posted June 22, 2012 The link for who wants to see it pretty impressive work RWD RS2K Link to comment Share on other sites More sharing options...
keithw1990 Posted June 22, 2012 Author Share Posted June 22, 2012 (edited) the engine is standard as far as i know.for now.http://i1088.photobucket.com/albums/i322/kwheelwr/270520121175.jpghttp://i1088.photobucket.com/albums/i322/kwheelwr/270520121176.jpghttp://i1088.photobucket.com/albums/i322/kwheelwr/mid%20engine%20escort/030520121155.jpgmore picsas someone now put the link up most of the build picture thank you for that i couldnt get it to work last time i tried,so engine is standard rs2k hottunning manifold & superchip, i also have a pipercross filter & home made induc kit but needs mod to fit now the engine is in the middleof the carhttp://i1088.photobucket.com/albums/i322/kwheelwr/07052011401.jpgalso now changed my mind on the engine cover its not pritty its noisey and fumeyhttp://i1088.photobucket.com/albums/i322/kwheelwr/230520121163.jpgi am now building a full bulkhead instead i found a window on ebay just waiting for it i will keep you all up to date thanks for all the intrest & nice comments Edited June 23, 2012 by keithw1990 Link to comment Share on other sites More sharing options...
keithw1990 Posted June 25, 2012 Author Share Posted June 25, 2012 hi guysdo you have any nmeetings in the essex area ? Link to comment Share on other sites More sharing options...
Stu Posted June 25, 2012 Share Posted June 25, 2012 hi guysdo you have any nmeetings in the essex area ? Not really, there aren't any meets at all these days. You could try and organise one though? I'm sure a few people would be interested in looking at your converted Escort. Speaking of which, do you have any plans to put an engine back in the front and run it twin-engined? Link to comment Share on other sites More sharing options...
Craig855S Posted June 26, 2012 Share Posted June 26, 2012 Whilst putting an engine and box back in the front would be a doddle, i imagine connecting 2 gearboxes to one stick would be a right mare? Link to comment Share on other sites More sharing options...
bongo Posted June 26, 2012 Share Posted June 26, 2012 Whilst putting an engine and box back in the front would be a doddle, i imagine connecting 2 gearboxes to one stick would be a right mare? should nt see why not,both gearboxes are facing the same way and both on the same side. think it would be the case of a long rod/ bar joining both with the gear stick joining th bar in the same place. Link to comment Share on other sites More sharing options...
Stu Posted June 26, 2012 Share Posted June 26, 2012 Easier said than done. Link to comment Share on other sites More sharing options...
keithw1990 Posted June 26, 2012 Author Share Posted June 26, 2012 Easier said than done.nothing in life is simple lol i think if i tried it i would use second set of cables off sane stick when i did first set i left room just in case, the other problems is getting these engines to run on small amount of wiring & the exhaust which i have looked at lots of times while building this one, i will enjoy my car as mid engine this year & see what happens over the winter i just love all the new found grip at the moment Link to comment Share on other sites More sharing options...
Stu Posted June 26, 2012 Share Posted June 26, 2012 Easier said than done.nothing in life is simple lol i think if i tried it i would use second set of cables off sane stick when i did first set i left room just in case, the other problems is getting these engines to run on small amount of wiring & the exhaust which i have looked at lots of times while building this one, i will enjoy my car as mid engine this year & see what happens over the winter i just love all the new found grip at the moment Cool. I'm in Essex so if you need a hand let me know. I've looked into a couple of twin-engined projects in the past so have done some research. The last incarnation was going to use 4F27E auto transmissions of which I was going to build a controller to actuate both transmissions at the same time. Link to comment Share on other sites More sharing options...
keithw1990 Posted July 5, 2012 Author Share Posted July 5, 2012 hi i made a start on the full bulkheadhttp://i1088.photobucket.com/albums/i322/kwheelwr/020720121281.jpghttp://i1088.photobucket.com/albums/i322/kwheelwr/020720121280.jpgso now you can see the engine better i need to make it pretty lol Link to comment Share on other sites More sharing options...
keithw1990 Posted July 5, 2012 Author Share Posted July 5, 2012 i brought this at rs central day but havent got round to fitting it yet, i do think i need a red cam cover now, what do you all think?http://i1088.photobucket.com/albums/i322/kwheelwr/040720121282.jpghttp://i1088.photobucket.com/albums/i322/kwheelwr/040720121283.jpg Link to comment Share on other sites More sharing options...
Naylor2006 Posted July 5, 2012 Share Posted July 5, 2012 Are you removing the engine box then? Link to comment Share on other sites More sharing options...
keithw1990 Posted July 6, 2012 Author Share Posted July 6, 2012 Are you removing the engine box then?yes mate you couldnt see the engine enough Link to comment Share on other sites More sharing options...
Naylor2006 Posted July 6, 2012 Share Posted July 6, 2012 Are you removing the engine box then?yes mate you couldnt see the engine enough What about some other of enclosure, so it looks more snug? If you care about that sort of thing lol Link to comment Share on other sites More sharing options...
Stu Posted July 20, 2012 Share Posted July 20, 2012 Good to see this on show today Front engine............ Link to comment Share on other sites More sharing options...
