scottybo Posted September 9, 2012 Share Posted September 9, 2012 whats is needed.to fit one. how would i do it and how much am i looking at paying for it all? Link to comment Share on other sites More sharing options...
Naylor2006 Posted September 9, 2012 Share Posted September 9, 2012 (edited) Basically this http://www.enginebasics.com/Engine%20Basics%20Root%20Folder/Images/oilcooler2.jpg You have to send the oil away from its usual route to the aux rad which you will need to mount somewhere front facing I guess, rest is plumbing. Erm...£150 ish new. Edited September 9, 2012 by Naylor2006 Link to comment Share on other sites More sharing options...
Ahmotorsport Posted September 9, 2012 Share Posted September 9, 2012 When fitting it, fill the oil cooler and pipes with oil. Take plugs out, disconnect fuel and sparks, spin over for a little while to get oil everywhere. Check oil level and run it up. Link to comment Share on other sites More sharing options...
Stu Posted September 10, 2012 Share Posted September 10, 2012 whats is needed An oil temperature problem. Do you have one? Oil coolers can do more bad than good if not needed. Link to comment Share on other sites More sharing options...
SLEEMAN Posted September 10, 2012 Share Posted September 10, 2012 Or if you get a kit with a thermostat on the plate then they would be better to use for every day use the ones that directly send oil consistently to the cooler you will encounter problems Link to comment Share on other sites More sharing options...
Stu Posted September 10, 2012 Share Posted September 10, 2012 I don't think i've seen any with a thermostat which switches high enough! Link to comment Share on other sites More sharing options...
SLEEMAN Posted September 10, 2012 Share Posted September 10, 2012 I know mocal do them and I think it's at the point of 80 degrees it sends the oil to the cooler I did have one was gonna use it on my track car but never got round to it and sold it on Link to comment Share on other sites More sharing options...
Stu Posted September 10, 2012 Share Posted September 10, 2012 Exactly my point. 80c is a ridiculous temperature. Link to comment Share on other sites More sharing options...
scottybo Posted September 10, 2012 Author Share Posted September 10, 2012 k fair one cheers for the info lads was just wondering as i thought cooling the engine a little more could never be a bad problem but if u recon theyre pants then i wont bother lol Link to comment Share on other sites More sharing options...
Ahmotorsport Posted September 10, 2012 Share Posted September 10, 2012 k fair one cheers for the info lads was just wondering as i thought cooling the engine a little more could never be a bad problem but if u recon theyre pants then i wont bother lolOf course they're not pants, just not necessary if the oils not getting too hot. Link to comment Share on other sites More sharing options...
JC Posted September 10, 2012 Share Posted September 10, 2012 Exactly my point. 80c is a ridiculous temperature. curious as to why you say that? as i "thought" the "optimum" temperature for oil was 80 degress? thus you would want the cooler to open and function at anything about 80? Link to comment Share on other sites More sharing options...
Ahmotorsport Posted September 10, 2012 Share Posted September 10, 2012 (edited) Exactly my point. 80c is a ridiculous temperature. curious as to why you say that? as i "thought" the "optimum" temperature for oil was 80 degress? thus you would want the cooler to open and function at anything about 80?oil should run at 100-110 degrees. Does vary for oil types but that's a rough figure. Edited September 10, 2012 by Ahmotorsport Link to comment Share on other sites More sharing options...
Naylor2006 Posted September 10, 2012 Share Posted September 10, 2012 (edited) Exactly my point. 80c is a ridiculous temperature. curious as to why you say that? as i "thought" the "optimum" temperature for oil was 80 degress? thus you would want the cooler to open and function at anything about 80?oil should run at 100-110 degrees. Does vary for oil types but that's a rough figure. My cheap gauge reflects those figures, however driving hard enough for long enough it will rise beyond that but yeh surely for normal fast road use there isnt much point. You'd def need a thermostat setup of some kind, dont know much about them but on a cold winter morning I would expect the oil would stay pretty cool for a long time. Edited September 10, 2012 by Naylor2006 Link to comment Share on other sites More sharing options...
Ahmotorsport Posted September 10, 2012 Share Posted September 10, 2012 My cheap gauge reflects those figures, however driving hard enough for long enough it will rise beyond that but yeh surely for normal fast road use there isnt much point. You'd def need a thermostat setup of some kind, dont know much about them but on a cold winter morning I would expect the oil would stay pretty cool for a long time.On the race cars on a cold winters day we have to block half the rad and oil cooler off to keep the temps up. Link to comment Share on other sites More sharing options...
Naylor2006 Posted September 10, 2012 Share Posted September 10, 2012 (edited) My cheap gauge reflects those figures, however driving hard enough for long enough it will rise beyond that but yeh surely for normal fast road use there isnt much point. You'd def need a thermostat setup of some kind, dont know much about them but on a cold winter morning I would expect the oil would stay pretty cool for a long time.On the race cars on a cold winters day we have to block half the rad and oil cooler off to keep the temps up. Been working nights all last week so have been leaving for home at about 6am each morning, theres a short drive onto the M5 and its been very cold lately down south, my oil takes a hell of a long time to warm up, drive it real easy until it does, an oil cooler would compound the issue. Still find it amazing how quickly the oil cools down now to be honest, in the time it takes to fill the tank its dropped down a fair bit. Edited September 10, 2012 by Naylor2006 Link to comment Share on other sites More sharing options...
