Mike-evans Posted September 25, 2012 Author Share Posted September 25, 2012 Not got a hoist yet Marc... Want to get this engine change right and wthl as little snags as possible, so what can I do to help it go easier... Soak exhaust bolts with oil the night before? What is the best way to undo all 3 mounts? Including rear gearbox mount? When fitting the new clutch, what is the best way to align it (never fitted a clutch before)? Link to comment Share on other sites More sharing options...
Stu Posted September 25, 2012 Share Posted September 25, 2012 Clutches tend to come with an alignment tool Link to comment Share on other sites More sharing options...
bongo Posted September 25, 2012 Share Posted September 25, 2012 we know your wishbones will come off easy enough,also you exhaust should to,soak the exhaust manifold bolts. Link to comment Share on other sites More sharing options...
Ahmotorsport Posted September 25, 2012 Share Posted September 25, 2012 Exhaust nuts should be alright, but no harm in soaking them. They have a coating on them that helps them not to seize on with heat. Alignment tools with clutches are a thing of the past! Link to comment Share on other sites More sharing options...
Mike-evans Posted September 25, 2012 Author Share Posted September 25, 2012 we know your wishbones will come off easy enough,also you exhaust should to,soak the exhaust manifold bolts. Yeah Im sure the wishbones will be easy to remove, could do them blind folded lol... Ps did you get my text? Exhaust nuts should be alright, but no harm in soaking them. They have a coating on them that helps them not to seize on with heat. Alignment tools with clutches are a thing of the past! Without a clutch alignment tool ( not sure if theres one with the clutch kit), whats the best way to align it? Link to comment Share on other sites More sharing options...
bongo Posted September 25, 2012 Share Posted September 25, 2012 yes mike. ive always aligned mine by eye lol,will be easy though as we will be bolt the box on on the floor. Link to comment Share on other sites More sharing options...
Ahmotorsport Posted September 25, 2012 Share Posted September 25, 2012 Without a clutch alignment tool ( not sure if theres one with the clutch kit), whats the best way to align it?You can buy a tool if you really want, but it can be done by eye just as easily. Link to comment Share on other sites More sharing options...
sidrick Posted September 26, 2012 Share Posted September 26, 2012 Never once saw a clutch come with an alignment tool and I must have ordered 50+ from loads of different manufacturers. The tools are cheap enough online. Link to comment Share on other sites More sharing options...
JC Posted September 26, 2012 Share Posted September 26, 2012 Clutches tend to come with an alignment toolDo they? My genuine ford one and the ap one didn't...n Link to comment Share on other sites More sharing options...
Ahmotorsport Posted September 26, 2012 Share Posted September 26, 2012 Clutches tend to come with an alignment toolDo they? My genuine ford one and the ap one didn't...nIts like wheel bearings that come with grease. Thing of the past. Link to comment Share on other sites More sharing options...
Stu Posted September 26, 2012 Share Posted September 26, 2012 Clutches tend to come with an alignment toolDo they? My genuine ford one and the ap one didn't...n It's been many years since I looked at a brand new clutch so perhaps they don't anymore! Link to comment Share on other sites More sharing options...
Scort_CVH Posted September 26, 2012 Share Posted September 26, 2012 (edited) Hi mate ive just done this so ill say how I did it. Had access to:tool kit - sockets, spanners, pry bars, screwdrivers etc etcHoistJack and stands Drop the engine and box in one piece - so much easier Disconnect your air box and piping and get it out your way. Youll need to unplug the 3 multiplugs for the engine loom aswell as starter loom and theres a few plugs that have there own loomsCoolant hoses.PAS hoses (leave the metal one bolted to the engine Remember - speedo cable! Oil pressure switch and gear linkages Id leave the inner cvs in box to save it making a mess of your driveCrack off the hub nuts with the wheels on the ground finally all the mounts are easy bar the rear gearbox mount - youll need to remove the L shape metal bracket that sits on the studs before ill come out and use a pry bar and in general Pee about with it Before it goes in cut about 10mm off the bottom stud! - life so much easier also split the mani and downpipe and leave mani on engine to save risking shearing studs where it matters Edited September 26, 2012 by Scort_CVH Link to comment Share on other sites More sharing options...
Mike-evans Posted September 26, 2012 Author Share Posted September 26, 2012 (edited) Hi mate ive just done this so ill say how I did it. Had access to:tool kit - sockets, spanners, pry bars, screwdrivers etc etcHoistJack and stands Drop the engine and box in one piece - so much easier Disconnect your air box and piping and get it out your way. Youll need to unplug the 3 multiplugs for the engine loom aswell as starter loom and theres a few plugs that have there own loomsCoolant hoses.PAS hoses (leave the metal one bolted to the engine Remember - speedo cable! Oil pressure switch and gear linkages Id leave the inner cvs in box to save it making a mess of your driveCrack off the hub nuts with the wheels on the ground finally all the mounts are easy bar the rear gearbox mount - youll need to remove the L shape metal bracket that sits on the studs before ill come out and use a pry bar and in general Pee about with it Before it goes in cut about 10mm off the bottom stud! - life so much easier also split the mani and downpipe and leave mani on engine to save risking shearing studs where it matters cheers the new engine hasnt got the manifold attached, so ill have to use mine, so will have to remove the nuts... also, what is the best way to remove gear linkages (forgot about them lol).... Edited September 26, 2012 by Mike-evans Link to comment Share on other sites More sharing options...
bongo Posted September 26, 2012 Share Posted September 26, 2012 gear linkage is a 10mm nut and gearbox stabiliser is 13mm bolt. Link to comment Share on other sites More sharing options...
etrebus Posted September 26, 2012 Share Posted September 26, 2012 Never once saw a clutch come with an alignment tool and I must have ordered 50+ from loads of different manufacturers. The tools are cheap enough online. i fitted as 206 clutch the other day and it came with one was most usefull it now lives in my tool box Link to comment Share on other sites More sharing options...
