m787srj Posted November 26, 2012 Share Posted November 26, 2012 car starts and run perfect but i get no power to heater blowers, wipers or indicators any help would be great.it happened before and then worked again now they won't work Link to comment Share on other sites More sharing options...
Stu Posted November 26, 2012 Share Posted November 26, 2012 I'd start by looking at the fuse box. Link to comment Share on other sites More sharing options...
m787srj Posted November 26, 2012 Author Share Posted November 26, 2012 I'd start by looking at the fuse box.i only changed it last year. some one said it could be the ignition switch. hazzard lights work and fuses are all good Im lost and thanks Link to comment Share on other sites More sharing options...
Stu Posted November 26, 2012 Share Posted November 26, 2012 Did you change it with a brand new one from Ford? Link to comment Share on other sites More sharing options...
m787srj Posted November 26, 2012 Author Share Posted November 26, 2012 Did you change it with a brand new one from Ford?no was second hand but i striped it down and checked it over before i put it in Link to comment Share on other sites More sharing options...
m787srj Posted November 26, 2012 Author Share Posted November 26, 2012 had a spare ignition switch so just tried it out didn't work so I'll. look for a fuse box then. cheers Link to comment Share on other sites More sharing options...
shawdreamer Posted November 26, 2012 Share Posted November 26, 2012 had a spare ignition switch so just tried it out didn't work so I'll. look for a fuse box then. cheers the symptoms your describing are have too much variance between them, there not even supplied by the same branch of the cab loom which means it can only be the one feature they all have in common and that's the fusebox. Link to comment Share on other sites More sharing options...
m787srj Posted November 26, 2012 Author Share Posted November 26, 2012 does the fusebox codes have to be identical or is it just the last 3 letters Link to comment Share on other sites More sharing options...
Rockerrob666 Posted November 26, 2012 Share Posted November 26, 2012 try checking the metal pins in the multiplugs that connect everything to the fusebox- wouldn't be supprised if a few where 'dislodged' when taken out then put back in when you changed the fusebox. intermittant power failure is more commonly a poor connection somewhere, as Shawdreamer says, the only common place is the fusebox and as it was changed last year, I'd check all the wires are in the blocks properly - you've had it working at some point from what you say, so the fusebox does work with it. good luck. Link to comment Share on other sites More sharing options...
m787srj Posted November 27, 2012 Author Share Posted November 27, 2012 try checking the metal pins in the multiplugs that connect everything to the fusebox- wouldn't be supprised if a few where 'dislodged' when taken out then put back in when you changed the fusebox. intermittant power failure is more commonly a poor connection somewhere, as Shawdreamer says, the only common place is the fusebox and as it was changed last year, I'd check all the wires are in the blocks properly - you've had it working at some point from what you say, so the fusebox does work with it. good luck.  car been running on road for a year or more but i will check thanks Link to comment Share on other sites More sharing options...
m787srj Posted November 28, 2012 Author Share Posted November 28, 2012 anyone know where i can find a relay diagram and fuse box diagram?? Link to comment Share on other sites More sharing options...
Ahmotorsport Posted November 28, 2012 Share Posted November 28, 2012 Haynes Manual perhaps? Link to comment Share on other sites More sharing options...
james08 Posted November 29, 2012 Share Posted November 29, 2012 autodata should have it Link to comment Share on other sites More sharing options...
m787srj Posted January 5, 2013 Author Share Posted January 5, 2013 got a brand new fuse box from ford. problem now is i have power and car now starts but i have no headlights, indicators or wipers. anyone no what might be causing this. everything changed over all new fuses. old relays and all connectors are pushed in correctly i will double check all this in the morning. any info is a great help.thanks for previous feedback. Link to comment Share on other sites More sharing options...
Stu Posted January 5, 2013 Share Posted January 5, 2013 Does the new fuse box have an identical part number? Link to comment Share on other sites More sharing options...
