etrebus Posted November 30, 2012 Share Posted November 30, 2012 My money's on rear main crank seal. Yep and mine, thats why I asked how hard is it to remove the flywheel? Box out, clutch and flywheel off, old seal out and new fitted - is that what needs to be done?not to hard bolts will be tight you may have to get someone to hold the flywheel using a bolt screwed into the bellhousing and with a strong screwdriver use the bolt as a pivot point to hold the flywheel using the ring gear the flywheel will have to be torqued up again after . Link to comment Share on other sites More sharing options...
Mike-evans Posted November 30, 2012 Author Share Posted November 30, 2012 Just had it up on the ramps....bad leak.... Annoying more than anything, as I only fittdd the 2.0l around 2 months ago.. Just been quoted £170 parts and labour to get it done, how does that sound? I am thinking about doing it myself, but do have afew questions;How hard is it to drop the gearbox whilst engine is still in the car?Rouhly how long has it taken people to drop the box?How hard is the crank seal to remove and new one to fit? Link to comment Share on other sites More sharing options...
sidrick Posted November 30, 2012 Share Posted November 30, 2012 For £170 I'd pay someone to drop the box unless you have access to a ramp. Zero fun on your back. Link to comment Share on other sites More sharing options...
Ahmotorsport Posted November 30, 2012 Share Posted November 30, 2012 I do have to agree with Sid. The gearbox mounts on an Escort can be a right pig. Link to comment Share on other sites More sharing options...
hicksy Posted November 30, 2012 Share Posted November 30, 2012 For £170 I'd pay someone to drop the box unless you have access to a ramp. Zero fun on your back. This man speaks sense. And its cold lying on the floor. I know this from putting the engine back in my RS last week. Link to comment Share on other sites More sharing options...
etrebus Posted November 30, 2012 Share Posted November 30, 2012 Just had it up on the ramps....bad leak.... Annoying more than anything, as I only fittdd the 2.0l around 2 months ago.. Just been quoted £170 parts and labour to get it done, how does that sound? I am thinking about doing it myself, but do have afew questions;How hard is it to drop the gearbox whilst engine is still in the car?Rouhly how long has it taken people to drop the box?How hard is the crank seal to remove and new one to fit?did you fit the engine yourself if so just take it back out again if you remove the front pulley it will come out on its own bit tight but you can do it Link to comment Share on other sites More sharing options...
Ahmotorsport Posted November 30, 2012 Share Posted November 30, 2012 I'm confused, which seal has gone? :') Link to comment Share on other sites More sharing options...
Mike-evans Posted November 30, 2012 Author Share Posted November 30, 2012 (edited) Yes I did fit the engine myself.. Rear crank seal (one behind flywheel)... Probably will do it myself, just for the learning side of it only concern I have is removal of flywheel Edited November 30, 2012 by Mike-evans Link to comment Share on other sites More sharing options...
Ahmotorsport Posted November 30, 2012 Share Posted November 30, 2012 Yes I did fit the engine myself.. Rear crank seal (one behind flywheel)... Probably will do it myself, just for the learning side of it only concern I have is removal of flywheel That should be the least of your worries. Link to comment Share on other sites More sharing options...
Mike-evans Posted November 30, 2012 Author Share Posted November 30, 2012 AH-enlighten me, so I know what to watch out for.... Link to comment Share on other sites More sharing options...
SLEEMAN Posted November 30, 2012 Share Posted November 30, 2012 i agree with sid for all the agro and pain not to mention sweat blood and tears pay someone to do it for £170!! trust me thats pretty cheap! Link to comment Share on other sites More sharing options...
etrebus Posted November 30, 2012 Share Posted November 30, 2012 Yes I did fit the engine myself.. Rear crank seal (one behind flywheel)... Probably will do it myself, just for the learning side of it only concern I have is removal of flywheel if you can fit an engine you can change a rear main oil seal easy 1.engine or gear box out you decide 2.clutch off3.flywheel off4.seal housing off 5. replace seal to housing 6.fit housing back 8. flywheel back 9.gearbox/engine back 10.have a beer Link to comment Share on other sites More sharing options...
Mike-evans Posted November 30, 2012 Author Share Posted November 30, 2012 How do you mean "seal housing off" I thought the seal has to be pulled out of the casing, and a new on fitted in... I didnt think the seal was in a seperate housing of its own? Link to comment Share on other sites More sharing options...
etrebus Posted November 30, 2012 Share Posted November 30, 2012 How do you mean "seal housing off" I thought the seal has to be pulled out of the casing, and a new on fitted in... I didnt think the seal was in a seperate housing of its own?its in an aluminium housing thats bolted to the block Link to comment Share on other sites More sharing options...
Mike-evans Posted November 30, 2012 Author Share Posted November 30, 2012 Is this how the rear crank seal is on a 2.0l Silvertop? http://i480.photobucket.com/albums/rr167/mike-evans/crankshaft_oil_seal.jpg Link to comment Share on other sites More sharing options...
