dalelc16 Posted March 19, 2013 Share Posted March 19, 2013 i have done a st170 rear brake converstion on the rear whick makes your rear wheel stick out by 15mm ish.so i cut the iner arch back and it was fine for my 17inch wheels but today i put on some escort cosworth wheels and they stick out more.the tyres are stretchd as well. my question to any one is do i need to fit bump stops?what elc can i do to make them fit with out rubbing? its for a escort gti. cheers Link to comment Share on other sites More sharing options...
scottybo Posted March 19, 2013 Share Posted March 19, 2013 change them, the offsets wrong anywya on escos wheels, they rub like a bitch on standard Link to comment Share on other sites More sharing options...
dalelc16 Posted March 19, 2013 Author Share Posted March 19, 2013 how does most people do it? Link to comment Share on other sites More sharing options...
SLEEMAN Posted March 19, 2013 Share Posted March 19, 2013 I know you have cut them back but what about rolled or flared arches? And maybe raise the suspension a bit lol! I know it has been done before that conversion with escos wheels he managed and he had rolled arches, other wise it may be wider arches! Lol Link to comment Share on other sites More sharing options...
Hezz Posted March 19, 2013 Share Posted March 19, 2013 What size tyres? Link to comment Share on other sites More sharing options...
dalelc16 Posted March 19, 2013 Author Share Posted March 19, 2013 What size tyres? 205 45. i no i should put 195 but i would like to keep the same size all round.the car i lowerd 30mm but if i put the normal springs back in and put bump stops on. Link to comment Share on other sites More sharing options...
PeeWee Posted March 19, 2013 Share Posted March 19, 2013 We've moved this topic into the correct section. Link to comment Share on other sites More sharing options...
GingeRS2K Posted March 19, 2013 Share Posted March 19, 2013 Swap them for Mondeo ones (7J ET35) no rubbing and looks spot on. Link to comment Share on other sites More sharing options...
SLEEMAN Posted March 19, 2013 Share Posted March 19, 2013 i've seen on passionford that the offset can be changed to suit, just needs to go on a lathe to reduce increase the offset Link to comment Share on other sites More sharing options...
dalelc16 Posted March 19, 2013 Author Share Posted March 19, 2013 i've seen on passionford that the offset can be changed to suit, just needs to go on a lathe to reduce increase the offset i was also thinking the same thing. get the alloy shaved at the back wer the hub sits. Link to comment Share on other sites More sharing options...
SLEEMAN Posted March 19, 2013 Share Posted March 19, 2013 yeah indeed but you can't shave too much off they are standard et25 and in order to achieve escort offset you will need to shave off about 15mm at least and thats alot of metal! so i would only shave off so much to the point where its safe either that or try and do the same technique to the hub or beam Link to comment Share on other sites More sharing options...
dalelc16 Posted March 19, 2013 Author Share Posted March 19, 2013 yeah indeed but you can't shave too much off they are standard et25 and in order to achieve escort offset you will need to shave off about 15mm at least and thats alot of metal! so i would only shave off so much to the point where its safe either that or try and do the same technique to the hub or beam ideal thanx for the help Link to comment Share on other sites More sharing options...
Hezz Posted March 19, 2013 Share Posted March 19, 2013 205 40 tyres are what a lot of people use iirc Link to comment Share on other sites More sharing options...
dalelc16 Posted March 20, 2013 Author Share Posted March 20, 2013 205 40 tyres are what a lot of people use iirc i also have a st170 coverstion so rhe wheels stick out more than drumss. what do people do to make them fit under the arch Link to comment Share on other sites More sharing options...
SLEEMAN Posted March 20, 2013 Share Posted March 20, 2013 I've seen 195/45/16 on cossies and its not that much of a stretch. Just enough but the lip of the wheel does stick out so avoiding kerbs are a must! Link to comment Share on other sites More sharing options...
