redmex Posted March 30, 2013 Share Posted March 30, 2013 Hi Guys Im looking for advice on which oil filter to use when fitting a Mondeo silvertop engine in an Escort. I know the CVH filter will fit the engine and is 80mm long would it clear?.. As i havent fitted the mondeo lump yet I would like to know from someone who has done it with mondeo pump what will work?... Plz dont tell me to fit escort oil pump as i have a brand new Mondeo pump that came in a job lot of parts and therefore want to use it. Thanks Sparkie Link to comment Share on other sites More sharing options...
JC Posted March 30, 2013 Share Posted March 30, 2013 I didn't think the mondeo pump fitted??? Link to comment Share on other sites More sharing options...
etrebus Posted March 30, 2013 Share Posted March 30, 2013 (edited) I didn't think the mondeo pump fitted???you can keep the mondy pump if you fit a smaller filter and remove the brace to the engine mount your other option is could you put the internals of the new pump into a escort one .would be better to fit a escort one if you could Edited March 30, 2013 by etrebus Link to comment Share on other sites More sharing options...
Andy 3i Posted March 30, 2013 Share Posted March 30, 2013 For mine I used the escort oil pump and use the escort filter. Link to comment Share on other sites More sharing options...
andrewsalter Posted March 30, 2013 Share Posted March 30, 2013 When I put a 2.0 in my fiesta I used the mondeo oil pump and a ka oil filter. Link to comment Share on other sites More sharing options...
bongo Posted March 30, 2013 Share Posted March 30, 2013 rs turbo or when i went to my local motorfactors he gave me the smallest zetec one,but to this day dont know what it was off. Link to comment Share on other sites More sharing options...
redmex Posted March 31, 2013 Author Share Posted March 31, 2013 (edited) I didn't think the mondeo pump fitted??? your other option is could you put the internals of the new pump into a escort one .would be better to fit a escort one if you could I was thinking about that too as my escort pump only has 25k on it. As long as there's no wear on the casing that will be my fav route Anyone got a part number for the ka filter etc? Thanks for the input guys Edited March 31, 2013 by redmex Link to comment Share on other sites More sharing options...
hicksy Posted March 31, 2013 Share Posted March 31, 2013 (edited) I didn't think the mondeo pump fitted??? your other option is could you put the internals of the new pump into a escort one .would be better to fit a escort one if you could I was thinking about that too as my escort pump only has 25k on it. As long as there's no wear on the casing that will be my fav route Anyone got a part number for the ka filter etc? Thanks for the input guys I work in a factors bud, the later ka from 2002 onwards takes the same filter as the zetec engine, the earlier ones 1996-2002 take the CVH filter. The unipart numbers for the later filter is GFE375, and the number for the earlier one is GFE348 Also all Zetec engined mondeos and escorts have the same oil filter the GFE375 Edited March 31, 2013 by hicksy Link to comment Share on other sites More sharing options...
etrebus Posted March 31, 2013 Share Posted March 31, 2013 I was thinking about that too as my escort pump only has 25k on it. As long as there's no wear on the casing that will be my fav route Anyone got a part number for the ka filter etc? Thanks for the input guys25k is nothing i would check it inside first and if ok then fit that one Link to comment Share on other sites More sharing options...
redmex Posted April 1, 2013 Author Share Posted April 1, 2013 thanks for the help guys.. Here the difference between a CVH and Zetec filter from when i put a Zetec in a 68 Cortina.. By the way back when I did this 2005-2006 the donor car was £20 as scrap value was so low.. it was bargains galore! http://i16.photobucket.com/albums/b34/mk1tina/zetec-cvhfilters.jpg Link to comment Share on other sites More sharing options...
roboboyo Posted April 3, 2013 Share Posted April 3, 2013 thanks for the help guys.. Here the difference between a CVH and Zetec filter from when i put a Zetec in a 68 Cortina.. By the way back when I did this 2005-2006 the donor car was £20 as scrap value was so low.. it was bargains galore! http://i16.photobucket.com/albums/b34/mk1tina/zetec-cvhfilters.jpg I used a Clio Filter Link to comment Share on other sites More sharing options...
redmex Posted April 3, 2013 Author Share Posted April 3, 2013 thanks for the help guys.. Here the difference between a CVH and Zetec filter from when i put a Zetec in a 68 Cortina.. By the way back when I did this 2005-2006 the donor car was £20 as scrap value was so low.. it was bargains galore! http://i16.photobucket.com/albums/b34/mk1tina/zetec-cvhfilters.jpg I used a Clio Filter god isnt that small Link to comment Share on other sites More sharing options...
