dalelc16 Posted April 28, 2013 Share Posted April 28, 2013 Hi has any one had a collins powerchip fitted to there gti 1.8? Is it worth the cash?whats the gains? Link to comment Share on other sites More sharing options...
PeeWee Posted April 28, 2013 Share Posted April 28, 2013 We've moved this topic into the correct section. Link to comment Share on other sites More sharing options...
Stu Posted April 29, 2013 Share Posted April 29, 2013 Wrong section. No, it's not worth it. Link to comment Share on other sites More sharing options...
PeeWee Posted April 29, 2013 Share Posted April 29, 2013 Wrong section. No, it's not worth it.Its an electrical component that effects mechanical items.In reality it covers two sections but seeing as the item referred to is actually electrical! Link to comment Share on other sites More sharing options...
Stu Posted April 29, 2013 Share Posted April 29, 2013 I'm going to argue this because I have nothing better to do, if you think that makes the point any less valid then that is your choice. The sub-title for the mechanical forum is "Engines and Running Gear". The ECU and calibration is considered running gear. It runs the engine. However, the Electricals sub-title is about wiring, ICE and security, none of which are relevant to an ECU chip. And now i'm done Link to comment Share on other sites More sharing options...
scottybo Posted April 29, 2013 Share Posted April 29, 2013 i have one fitted to my 1.6 atm, does it give me any extra power? no not that really noticable but it does remove the flat spot lower down the rev range which increases drivability and gives better throttle responce Link to comment Share on other sites More sharing options...
PeeWee Posted April 29, 2013 Share Posted April 29, 2013 I wouldn't of thought an ecu chip was regarded as "running gear" tbf, I won't argue your point as you could be correct I'm no expert nor do I care Link to comment Share on other sites More sharing options...
dalelc16 Posted April 29, 2013 Author Share Posted April 29, 2013 i have one fitted to my 1.6 atm, does it give me any extra power? no not that really noticable but it does remove the flat spot lower down the rev range which increases drivability and gives better throttle responce Cheers so on there site it does say it improves bhp? Link to comment Share on other sites More sharing options...
scottybo Posted April 29, 2013 Share Posted April 29, 2013 weill it feels better with it on so im happy enough Link to comment Share on other sites More sharing options...
dalelc16 Posted April 29, 2013 Author Share Posted April 29, 2013 weill it feels better with it on so im happy enough Did you fit?it was it easy? Link to comment Share on other sites More sharing options...
Escort Si-130 Posted May 2, 2013 Share Posted May 2, 2013 The Collins Power chip in the mk5 Escort RS2000, combined with K&N panel Filter and stainless steel exhaust can see 169bhp, around 19bhp up on standard. Link to comment Share on other sites More sharing options...
Stu Posted May 3, 2013 Share Posted May 3, 2013 Dream on. Link to comment Share on other sites More sharing options...
scottybo Posted May 3, 2013 Share Posted May 3, 2013 weill it feels better with it on so im happy enough Did you fit?it was it easy? only pain was gettin the ecu out. once its oit juat plug it in the bottom. disconnect the battery for an hour. then reconnect and away you go! Link to comment Share on other sites More sharing options...
dalelc16 Posted May 3, 2013 Author Share Posted May 3, 2013 Stu dont think its that good by the sounds of things Link to comment Share on other sites More sharing options...
scottybo Posted May 3, 2013 Share Posted May 3, 2013 well i do. and the other chap agrees Link to comment Share on other sites More sharing options...
