JC Posted May 5, 2013 Share Posted May 5, 2013 How do you remove the fuel pump from a mk6 escort? without breaking it Link to comment Share on other sites More sharing options...
bongo Posted May 5, 2013 Share Posted May 5, 2013 there's a ring ontop that you need to turn anticlockwise,remove this and then the pump should lift out. Link to comment Share on other sites More sharing options...
JC Posted May 5, 2013 Author Share Posted May 5, 2013 there's a ring ontop that you need to turn anticlockwise,remove this and then the pump should lift out. any hints, and what tools to use? Link to comment Share on other sites More sharing options...
sidrick Posted May 5, 2013 Share Posted May 5, 2013 Screwsriver and hammer. Link to comment Share on other sites More sharing options...
JC Posted May 5, 2013 Author Share Posted May 5, 2013 Screwsriver and hammer. really??? don't want to break it Link to comment Share on other sites More sharing options...
bongo Posted May 5, 2013 Share Posted May 5, 2013 not sure john,i just went to look at the tank in the garden i got from the rs,are you using the force to do it or is it down on the ground to see?perhaps you may need to use sidricks tools to just to move the ring,its probably seized. Link to comment Share on other sites More sharing options...
JC Posted May 6, 2013 Author Share Posted May 6, 2013 thanks. tank is dropped, still has the cable going into it for now, but it seems to be jammed. may break out the hammer and have another play, just wondered if there were any tricks to removing them? Link to comment Share on other sites More sharing options...
sidrick Posted May 6, 2013 Share Posted May 6, 2013 I've never seen a pump being removed without the use of a hammer/mallet to undo the locking ring. Link to comment Share on other sites More sharing options...
sortedford Posted May 6, 2013 Share Posted May 6, 2013 Short sharp hit pal, do it on one of the tabs, then move to another one and keep doing it Link to comment Share on other sites More sharing options...
JC Posted May 6, 2013 Author Share Posted May 6, 2013 ok cheers guys thanks for the input Link to comment Share on other sites More sharing options...
Naylor2006 Posted May 6, 2013 Share Posted May 6, 2013 Having had my 3 different fuel pumps during fuel gauge gate I can second Sid, mallet and screw driver on the notches bit by bit, Im sure the proper tool would have been better as it would apply pressure on each notch all at the same time however didnt have one and couldnt find one. Just ditch it all, be like you to fit a shiny tank in the boot Link to comment Share on other sites More sharing options...
JC Posted May 6, 2013 Author Share Posted May 6, 2013 Just ditch it all, be like you to fit a shiny tank in the boot lol, the thought had crossed my mind... if i decide to turn it into a track car.... Link to comment Share on other sites More sharing options...
Ahmotorsport Posted May 6, 2013 Share Posted May 6, 2013 Aye hammer and screwdriver/drift. Very common, even old fuel senders (mine for example) are the same. Link to comment Share on other sites More sharing options...
