Muzz Posted June 2, 2005 Share Posted June 2, 2005 Im in the middle of purchasing a 115PS engine to swap with my 1.6 (When i get one ). What exactly do i need with the engine to make sure it works ok?? ECU, Manifolds and all the usual ancilleries. Have i missed anything? Also, what can i do with the ECU to get around PATS. Would chipping the 1.6 ECU rather than replacing it with the 1.8 ECU work? If so, where can i get the correct chip and where would be the best place to get it fitted? Or would i be better off going to an auto-sparky and getting him to rewire the ignition into the new ECU? Ta folks. Link to comment Share on other sites More sharing options...
marcus Posted June 2, 2005 Share Posted June 2, 2005 just buy a 1.8 to start, its a lot of farting about, if your gonna do it do it propper an do a 1.6-2.0, it wont cost u anymore!!! Link to comment Share on other sites More sharing options...
Muzz Posted June 2, 2005 Author Share Posted June 2, 2005 Cant afford the insurance for a 1.8 otherwise i would . Link to comment Share on other sites More sharing options...
walks Posted June 2, 2005 Share Posted June 2, 2005 insurance is normally higher on cars with transfered engines Link to comment Share on other sites More sharing options...
Muzz Posted June 2, 2005 Author Share Posted June 2, 2005 What they dont know doesn't hurt them . Link to comment Share on other sites More sharing options...
Ex-Finesse Posted June 2, 2005 Share Posted June 2, 2005 Find a 1.8 mk6 in a scrapyard and have the ecu, ignition barrel and the circuit around the barrel. That lot should get round PATS Link to comment Share on other sites More sharing options...
Lee R Posted June 2, 2005 Share Posted June 2, 2005 What they dont know doesn't hurt them .<{POST_SNAPBACK}> you might as well go 2.0 then Link to comment Share on other sites More sharing options...
Muzz Posted June 2, 2005 Author Share Posted June 2, 2005 (edited) Ask rob what the scrappys round here are like, talking £250 plus for that lot . Would chipping it not get around it? Edit: Lee, the only way you can tell a 1.6 from 1.8 is the bottom end components iirc, so if i crash the insurance people probably wouldnt even be able to tell that i had a 1.8 engine where as if i have a mondeo engine it, it is slightly more obvious . Edited June 2, 2005 by Muzz Link to comment Share on other sites More sharing options...
sortedford Posted June 2, 2005 Share Posted June 2, 2005 nah, without taking it apart the only way to tell on them is on the block where it says the size Link to comment Share on other sites More sharing options...
Muzz Posted June 2, 2005 Author Share Posted June 2, 2005 (edited) nah, without taking it apart the only way to tell on them is on the block where it says the size <{POST_SNAPBACK}> You on about the 2L or the 1.8/1.6? A bit of modification will get rid of that . Edited June 2, 2005 by Muzz Link to comment Share on other sites More sharing options...
Muzz Posted June 2, 2005 Author Share Posted June 2, 2005 Just rang ford and they told me that if the vehicle has PATS already then the ECU's should swap straight over without any problems. If it hasn't he basically said dont bother. So how do you tell if it has PATS or not? Link to comment Share on other sites More sharing options...
Mike C Posted June 2, 2005 Share Posted June 2, 2005 nah, without taking it apart the only way to tell on them is on the block where it says the size <{POST_SNAPBACK}> You on about the 2L or the 1.8/1.6? A bit of modification will get rid of that .<{POST_SNAPBACK}> either, all Zetecs are the same Link to comment Share on other sites More sharing options...
ploppy Posted June 3, 2005 Share Posted June 3, 2005 ru saying then that for example a 2l ecu from a mondeo would still work on a different ignition barrel provided it has pats? Link to comment Share on other sites More sharing options...
Ex-Finesse Posted June 3, 2005 Share Posted June 3, 2005 ru saying then that for example a 2l ecu from a mondeo would still work on a different ignition barrel provided it has pats?<{POST_SNAPBACK}>That's what I'm hoping....!! Plan to splice a mondeo multiplug into the escort wiring........ although mondeo owner says the car (a 1993) doesnt have PATS. Posed question on a mondy forum! Link to comment Share on other sites More sharing options...
Muzz Posted June 3, 2005 Author Share Posted June 3, 2005 Thats what they said mate, as all PATS is, is an immobiliser. So anyone know how i tell if the car i choose to buy has/hasn't got PATS? Link to comment Share on other sites More sharing options...
