ryanrs Posted August 16, 2005 Share Posted August 16, 2005 I have decided to do the 2.0 conversion in my 1.8 115ps '97 GTi, seems like a pritty straight foward and easy job.. the trickyist part, i would imagin is changing the pins in the connector, to run the 2.0 ECU. Now, while my 1.8 is still in and running, i would like to convert the 2.0 ECU 1st, so the tricky part is out of the way... If i do this, and its obviously done properly, will the 1.8 lump start and run off the 2.0 ECU ?? or do i need the 2.0 lump in there? reason i would like to do it in this order, is if the 2.0 ECU is fitted and running the 1.8 , i no its all working properly.. other than changing the ECU and Engine at the same time, finding out it dont start and then having to figure what went wrong. thanx Link to comment Share on other sites More sharing options...
Muzz Posted August 16, 2005 Share Posted August 16, 2005 There is 2 posts on here that detail how to change the ECU . http://www.escortevolution.co.uk/forums/in...showtopic=49026 & http://www.escortevolution.co.uk/forums/in...showtopic=50094 Link to comment Share on other sites More sharing options...
Ex-Finesse Posted August 16, 2005 Share Posted August 16, 2005 Good thinking there ryan. Remember you'll have to still change all the pins as detailed in the how-to to take into account the differences between escort and mondeo wiring looms Link to comment Share on other sites More sharing options...
foxdie Posted August 16, 2005 Share Posted August 16, 2005 what u actually do ralph, run the 2.0 as a piggy back just for the fueling? Link to comment Share on other sites More sharing options...
Ex-Finesse Posted August 16, 2005 Share Posted August 16, 2005 No mate, change the whole ecu box of tricks. Link to comment Share on other sites More sharing options...
foxdie Posted August 17, 2005 Share Posted August 17, 2005 No mate, change the whole ecu box of tricks. <{POST_SNAPBACK}> Doesn't the ECU control the keys etc? Link to comment Share on other sites More sharing options...
bluliz Posted August 17, 2005 Share Posted August 17, 2005 No mate, change the whole ecu box of tricks. <{POST_SNAPBACK}> Doesn't the ECU control the keys etc?<{POST_SNAPBACK}> thats Pats. Link to comment Share on other sites More sharing options...
Ex-Finesse Posted August 17, 2005 Share Posted August 17, 2005 If you have a later, PATS equipped ecu, you need the chip from the key which was with that car. I don't beleive anyone has tried this, however. Easiest thing is to swap some wires for a non-pats ecu. Link to comment Share on other sites More sharing options...
ryanrs Posted August 17, 2005 Author Share Posted August 17, 2005 If you have a later, PATS equipped ecu, you need the chip from the key which was with that car. I don't beleive anyone has tried this, however. Easiest thing is to swap some wires for a non-pats ecu. <{POST_SNAPBACK}> so if you have a leter model With PATS, you can use a NON-PATS ecu, and use your origional keys... just means you dont have an immobilizer - is that rite?? Link to comment Share on other sites More sharing options...
Ex-Finesse Posted August 17, 2005 Share Posted August 17, 2005 That's right. My guide is based on a car with pats using a non-pats ecu. But most people here will have an aftermarket alarm / immobiliser, so lack of pats is of little worry Link to comment Share on other sites More sharing options...
ploppy Posted August 17, 2005 Share Posted August 17, 2005 if i converted my 115ps engine to a 130ps engine, will using the 2.0l ecu result in more correct fueling and therefore release the full 130ps? its just that there are 130ps ecu's in my breakers. Link to comment Share on other sites More sharing options...
Ex-Finesse Posted August 17, 2005 Share Posted August 17, 2005 Use the 130 ecu mate. I have one for sale. How much can you get them for in your breakers?? Link to comment Share on other sites More sharing options...
ploppy Posted August 17, 2005 Share Posted August 17, 2005 probably about a tenner. seriously its well cheap depending on wot bloke is down there. Link to comment Share on other sites More sharing options...
ploppy Posted August 17, 2005 Share Posted August 17, 2005 i take it the 130ps ecu and the 2ltr ecu is totally different then. Link to comment Share on other sites More sharing options...
foxdie Posted August 17, 2005 Share Posted August 17, 2005 i take it the 130ps ecu and the 2ltr ecu is totally different then.<{POST_SNAPBACK}> i heard a rumour they are the same. Link to comment Share on other sites More sharing options...
