Joe Posted August 29, 2007 Share Posted August 29, 2007 A product that has recently come to promenance in the world of detailing is Detailing Clay. In this thread I aim to write a general guide to what clay is, what its used for and some generic tips for how to get results from clay. I will focus on the use of clay for the removal of bonded contaminants. What Is Detailing Clay??While clay is growing in popularity with many detailers now, it has certainly not become a well known "household" car detailing product. Detailing clay is a substance that is designed to remove bonded contaminatns from paint, leaving the paint smooth as glass, allowing easier and more fruitful applications of polihses, glazes, sealents and waxes. Detailing Clay is wiped gently across the paint which needs to be lubricated with a lubricant such as a Quick Detailer spray. Clay, like polishes, comes in levels of aggressiveness - if you are a beginner with clay, do start with a mild clay such as Meguiars Quik Clay, Meguiars Professional Mirror Glaze Clay (mild, the blue bar) or Sonus Green Clay. These mild clays should be enough to remove bonded contaminants from most cars, only step up to a more aggressive clay if absolutely needed. Clay can be used on paintwork, glass, and wheels. Always use separate clay on each - ie dont first clay your wheels then use the same clay to clay your paint, as all the brake dust embedded in the clay from the wheels will scratch the paint. What Are Bonded Contaminants??When you come to wash your car, the paint will be covered in lots of fresh contiaminats such as dust, mud, possibly bird boms and many others. In addition, the paint will also have a growing amount of bonded contaminants attached to it, which accumulate over time: When you wash your car, the fresh contaminants are removed from the paint and the paintwork looks clean. However, washing will leave behine the bonded contaminats which are attached to the paint as if they had been glued on: These bonded contaminats are hard to see, so after washing your paintwork looks clean. However, if you gently run your fingers acorss the paintwork you may feel that the paintwork feels rough - a bit like stubble in a way. This roughness, grittiness that you are feeling is the bonded contaminants in the paint. Examples of bonded contaminants are: > Brake dust - sharp, so embeds itself in the paint> Industrial fallout> Tree sap - very sticky so adheres strongly to the paint and there are many others as well which you're car is subjected to on a regular basis. Removing Bonded Contaminants - ClayIn order to remove the bonded contaminats and restore a glassy smooth feel to the paint, detailing clay is used. As well as leaving a pleasingly smooth feel to the paint, when you come to polish, glaze, seal or wax, it means that you are now sealing in remaining bonded contaminants if you have removed them by clay. Simply washing and waxing will not remove bonded contaminants, they will be left behind and then just waxed over. Clay basically works by grabbing hold of the bonded contaminants and pulling them off of the paint surface: The contmainats become stuck in the softer clay where they remain. A safety note when using clay here - these bonded contaminats are stuck into the clay and the clay represents a flat surface. Therefore, surface marring can occur if not enough lubricant is used, or the clay is not kneaded regularly enough to a clean side - please see also the section on using clay... This leaves the paint finish glassy smooth. Clay can remove the bonded contaminants listed above, however some adhesive contaminants such as tar may need a dedicated tar remover as they are very highly adhesive. Using ClayBefore claying, always wash fresh contaminants off of the car. First and foremost, always follow the manufacturers instruction for the correct use of their detailing clay. What follows here is a generic guide of tips for the safe use of clay which I use from experience of using clay. To clay your car, you will need a clay bar and an associated lubricant to lubricate the surface and the clay bar - examples of such lubricants are: > Meguiars Quick Detailer Spray> Meguiars Last Touch Detailing Spray> Meguiars #34 Final Inspection> Clearkote Clay Lubricant> Pinnacle Poly Clay Lubricant and there are others that can be used too. About 40 - 50g of clay is sufficient to clay a moderately sized car. If using Meguiars Quick clay, for example, break off one third to one half of the clay bar (the bigger the car, the more clay you may need). Roll the clay up into a ball, then out into a sausage shape and finally flatten it out into the palm of your hand. When doing this ensure that the clay is warm and quite soft. It clay gets cold, it can be hard or brittle and this can risk inducing surface marring on the paint. Throughout the claying process, always ensure that the clay remains nice and warm and doesn't go brittle or hard. Work on small areas at a time, I start with the roof, and then the bonnet, then the top half of the sides, then the boot, then the bottom half of the sides (like washing, do the cleaner areas first). I always spray a panel with quick detailer and wipe off before claying it to remove and rogue dust particles that may have blown onto the paint that may induce marring. Work on small areas of paintwork at a time - about 2' by 2'. Spray the area with the clay lubricant, enough to wet the surface quite thoroughly. Also spray the clay with lubricant as well. Gently wipe the clay in a fore and aft motion over the lubricated area using only finger light pressure: Never clay over a dry area of paint, and if the paint begins to dry out before you are happy that the surface contaminants have been removed (paint will feel smooth), spray on more lubricant. Keep the clay lubricated as well. Once the paintwork feels smooth, gently wipe the remaining clay lubricant away using a soft microfibre towel. Knead the clay very regularly - this not only keeps the clay warm, but when kneading expose a clean side of the clay. Remember that clay is picking up sharp particles, if you do the whole car with one side of clay you will induce surface marring as all the sharp particles stuck in the clay will ineveitably come into contact with the paint. For this reason, knead the clay regularly and only ever use finger light pressure. When a clean side of clay can no longer be revealed, discard the clay. Continue until the car is completed. Note that many clays will remove some or all (depending on aggressiveness) of the wax/sealent protection, so always follow up claying with polishing and glazing if required, followed by sealing and/or waxing. Some Notes on Safe Clay Use Clay is safe to use if used with care. However, if not used with care it can induce surface marring. Always regularly knead the clay to a clean side. Always keep both the clay and the paint surface well lubricated. Use only finger light pressure If you drop the clay on the ground, discard it as it will pick up tons of dust and grit and dirt from the ground that will inflict damage to paint. Keep clay warm, and supple - if it gets cold, hard and brittle it will induce marring, so another reason to keep kneading regularly, especially in winter. And there we have it, a quick generic starters' guide to clay. Link to comment Share on other sites More sharing options...
bluliz Posted August 29, 2007 Share Posted August 29, 2007 That will be useful.... Link to comment Share on other sites More sharing options...
Guest gti.tom Posted August 29, 2007 Share Posted August 29, 2007 I'm pretty worried about doing this. Is it that easy to fcuk up my paint with this? Link to comment Share on other sites More sharing options...
bluliz Posted August 29, 2007 Share Posted August 29, 2007 I'm pretty worried about doing this. Is it that easy to fcuk up my paint with this? As with everything in life....lube up and your fine Link to comment Share on other sites More sharing options...
Joe Posted August 29, 2007 Author Share Posted August 29, 2007 I'm pretty worried about doing this. Is it that easy to fcuk up my paint with this? Like i said mate, a nice mild clay, - Sonus green, with plenty of lube and your fine, keep an MF handy too Link to comment Share on other sites More sharing options...
Escort boy Posted August 30, 2007 Share Posted August 30, 2007 Nice guide Joe, will come in handy I'm pretty worried about doing this. Is it that easy to fcuk up my paint with this? As with everything in life....lube up and your fine Link to comment Share on other sites More sharing options...
Tez162003 Posted August 30, 2007 Share Posted August 30, 2007 clay is the dogs B*****KS! i just used some megs clay over my car, did f**king wonders! lol. but i then used another one over my gfs car (not cleaned all that often so loads of contaminents, and OMG it was soooo smooth afterwards! Definatly try clay! Link to comment Share on other sites More sharing options...
robexor Posted August 30, 2007 Share Posted August 30, 2007 (edited) gti.tom,,, this is so easy to do. i used the meguiars Smooth Surface Clay kit, cheap and everything you need. 2 X bars of clay1 X Bottle of Quick Detail [ also excelent for use after wash car ]1 X Small bottle of Wax [after use of clay, then wash, then wax] it does the 1 car and then still have a lil left1 X Large Microfiber cloth Edited August 30, 2007 by robexor Link to comment Share on other sites More sharing options...
Mike C Posted August 30, 2007 Share Posted August 30, 2007 You can't beat Zymol Lehm Clay and lube, it's MILES ahead of everything else out there Link to comment Share on other sites More sharing options...
Escort boy Posted August 30, 2007 Share Posted August 30, 2007 Like this Mike? http://www.premierbodyshops.co.uk/zymol/cl...Lehm-Klay_2.htmhttp://www.premierbodyshops.co.uk/zymol/cl...Lehm-Lube_2.htmhttp://www.premierbodyshops.co.uk/zymol/ac...accessories.htm Link to comment Share on other sites More sharing options...
MarkyMark Posted August 31, 2007 Share Posted August 31, 2007 You can't beat Zymol Lehm Clay and lube, it's MILES ahead of everything else out there There was a feature in this months fast ford. Cracking read and the results using Zymol products was amazing Link to comment Share on other sites More sharing options...
