blacksofstichill Posted August 21, 2013 Author Share Posted August 21, 2013 Brilliant Love the look of this, mk5 front end that is. Looks mean as fook! That is one mental journey to make! Why not have you build the engine and courier it down here though??? Thanks, yeah, I love how it looks from the front end too, very mean! You're right, it was certainly a long journey to make for the car to get up here! The original plan was for me to build the engine and then send it down but the car itself was due an MOT, needing some welding and also needing the engine fitted which is quite involved when you take into account it's going to be converted to Turbo. So he decided to bring it up to me so he could basically get the whole job done at the one place rather than get the welding done one place, engine fitted at another, etc. It turned out to be a much larger job than either of us anticipated (for welding work) but we've stuck with it and it's getting there. Another update on this, I fully welded up my crossmember mounting repair section on the inside of the car, I built up heavy fillet welds in all of the corners and ground them back so there is plenty of strength in it - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0722.jpg Looking at it from the outside you can see I still need to make a plate to fill in the hole at the front and a small infill piece to the inner sill - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0723.jpg Plate made for the front - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0724.jpg And welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0725.jpg Small infill plate made for the inner sile side - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0726.jpg And welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0727.jpg Viewed from underneath you can see that all 3 plates I made for this repair are fully welded to each other and they are all welded back to good solid original metal - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0728.jpg Looking from the inside of the car now you can see where my last couple of plates have filled in the gaps nearest to the inner sill - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0729.jpg Now I need to weld a plate in to the inner arch of the car to cover the area I had cut out, it's an awkward shape but this plate can be formed in place to cover most of it in one go - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0730.jpg With it all welded into place I'm only left with a small gap in the middle of the left hand side which goes around the corner towards the front of the car - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0731.jpg Plate cut to suit - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0732.jpg Welded into place and all of the welds ground back, this didn't photograph very well with the reflection off the shiny plate - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0733.jpg Looking back underneath again, the chassis rail had a small hole in it which I ground back until I had good clean metal to weld to - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0734.jpg Plate cut to shape - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0735.jpg and welded into place, you can see here that this repair is also tied into my crossmember repair section - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0736.jpg A small hole on the bottom of the chassis rail was also ground back to clean metal - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0737.jpg Plate made - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0738.jpg And welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0739.jpg When I'd been working inside the car I'd noticed that the floorpan in that corner didn't feel very strong and was ropey at the front edge, holes were very easily poked through it and became clear it wasn't very well welded on the inner sill side either - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0740.jpg This area had been plated before but the plate was very thin indeed and after a few years worth of corrosion it meant the plate was very weak - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0741.jpg Viewed from underneath you can see it isn't very well attached to the inner sill any more - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0742.jpg So, I cut that complete section of floor out between the chassis rails and the inner sills - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0743.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0744.jpg Link to comment Share on other sites More sharing options...
lee grout Posted August 21, 2013 Share Posted August 21, 2013 Bloody rust! I was also gonna ask, Why turbo a RS2k lump instead of a zetec? I always heard that zetecs are better than the other, just curious? Link to comment Share on other sites More sharing options...
sidrick Posted August 24, 2013 Share Posted August 24, 2013 Off topic, but do you use/recommend anyone for gearbox or differential rebuilds, or do you do it all yourself? Link to comment Share on other sites More sharing options...
blacksofstichill Posted September 7, 2013 Author Share Posted September 7, 2013 Bloody rust! I was also gonna ask, Why turbo a RS2k lump instead of a zetec? I always heard that zetecs are better than the other, just curious? Got to love the rust to keep you busy eh! The reason it was an RS2000 engine being used is mostly down to that being what the original engine was that he bought years ago. Because he already had that engine with Forged Pistons and rods, etc it made more sense to use those parts as a basis for a new build than to start a fresh build altogether. To be honest though, unless he had some trick Zetec Parts lying around already I'd probably still have converted an RS engine rather than a Zetec, mostly just to use the same type of engine that the car was originally fitted with. If it had been a GTI it was going into though, that would have been a different story. Off topic, but do you use/recommend anyone for gearbox or differential rebuilds, or do you do it all yourself? Sorry for the delay, I've not updated this for a while! It would depend what it was to be honest, some things I'd tackle myself, others would be a case of sourcing a second hand 'box or diff. I'm not sure but I'd guess that Dingbro will have a company they use for Transmission rebuilds that'll probably be up your way? I can try and find out if that's any help to you? With the section of floorpan cut out at the front I made a repair section to piece into it. I made it so it would fit from above to enable me to weld most of it from inside the car and the lip at the edge is for welding it to the sill from the underside - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0745.jpg Welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0746.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0747.jpg With the last bit of welding now done on that area of the car I was able to clean back, prime and seam seal that corner of the floor, etc - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0748.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0749.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0750.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0751.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0752.jpg One other area needing attention was the A-Post where the door stay had pulled right out of it- http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0753.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0754.jpg Rather than trying to weld a captive nut back in place which might just pull back out again I decided to cut a slot out of the post, it looks rough here but bare with me - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0755.jpg Cutting that slot out of the post meant I could slot in a heavier gauge plate and weld the post back up in front of it again, so I made a little plate with a captive nut welded to the back - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0756.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0757.jpg With the heavy plate slotted in and welded in place I was able to weld up the outer skin of the post again and grind it back, this way the heavy plate with the captive nut is held behind the outer skin of the post as well as being welded to the inner skin of the post so it isn't going to pull out of the post again - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0758.jpg A quick coat of primer and gloss black to protect the bare metal, when it comes to the final clean up of the car I'll most likely paint this again though - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0759.jpg Door Stay bolted back into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0760.jpg Moving on with the rest of the car, I cleaned up the sills along the bottom edge with a wire brush on a drill and the front section of sill is still solid, a bit more time spent cleaning it back and a coat of paint followed by schutz underseal will be all this needs - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0761.jpg Unfortunately the rear end of the sill isn't so good - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0762.jpg wih some more of the loose metal pulled back and looking from underneath you could see the inner sill was also looking like it might be needing some work too - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0763.jpg Outer sill cut back to solid metal - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0764.jpg With the outer sill off in this area you can see that the inner sill also needs to be cut back here too as it's very rusty - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0765.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0766.jpg The inner side of this which is part of the edge of the floor and start of the rear chassis was also crumbling away - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0767.jpg Not to worry though, it can all be cut out and replaced with good metal, so with some angle grinder action I cut out the rusty areas of the inner sill, etc - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0768.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0769.jpg First thing to do now is to cut a flat repair section of sheet to be welded to the remaining flat section of existing inner sill, this also creates a flange I can weld against on the inside and outsde of the sill - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0770.jpg And welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0771.jpg Now I need to replace the bottom edge of the channel section of inner sill, here is my repair section for it - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0772.jpg And welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0773.jpg Link to comment Share on other sites More sharing options...
blacksofstichill Posted September 7, 2013 Author Share Posted September 7, 2013 On the inside of the inner sill, the edge of the floor is quite an awkward shape so I decided to repair it with 3 seperate pieces, starting off at the front and working my way back - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0774.jpg First repair section made - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0775.jpg And welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0776.jpg My next repair section made - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0777.jpg Welded into place, this section over laps the first piece I made slightly to make sure it has plenty of strength - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0778.jpg Last but not least there is a small infill piece required for the very end of the inner sill - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0779.jpg And welded into place, also lapping onto the previous repair section, you can see the extent of the area I've replaced here, some of the welds still need to be dressed back but it's nice and solid now and gives me a good bit of metal to weld my outer sill repair onto - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0780.jpg With the inner sill repaired I was able to make a repair section for the outer sill now that I had something solid to weld it to - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0781.jpg And welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0782.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0783.jpg With that now sorted it was time to look further back on the car to see what needed repaired next, first up here's a hole in the front end of the rear chassis leg where the front mount for the rear axle is ocated - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0784.jpg Further back there was a split appearing on the chassis leg near where the subframe bolted up - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0785.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0786.jpg Various other splits and holes on the drivers rear chassis leg, mostly at mounting points too - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0787.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0788.jpg Back to the start of the rear chassis the hole I'd found earlier was much bigger with a little bit of prodding - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0789.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0790.jpg Slightly further back there was another hole and some very crumbly metal - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0791.jpg I knew I'd have to lower the rear axle to get access to weld some of these bits, what I found though was that this mounting plate had been welded to the chassis when a previous plate was fitted so it had to be ground off - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0792.jpg The extent of some of the rust further back on the chassis is more obvious now too - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0793.jpg With the axle dropped down slightly you can see the full extent of the rust at the front end of the rear chassis leg, this rust starts basically right behind the inner section I'd just repaired so I know I have good metal to weld to - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0794.jpg Starting with the hole at the front, I cut out the rust and made the hole larger in the process - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0795.jpg Repair plate cut to size - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0796.jpg And welded into place, not handy when it's right next to the fuel tank - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0797.jpg Link to comment Share on other sites More sharing options...
ganges Posted September 7, 2013 Share Posted September 7, 2013 (edited) cracking updates, mate, and a good job, bloody hell you got some rust issues there nice to see this coming along though, keep up the good work:thumb: Edited September 7, 2013 by ganges Link to comment Share on other sites More sharing options...
lee grout Posted September 7, 2013 Share Posted September 7, 2013 Think the repair bill will be a bit of a surprise Good work though. As soon as you look for rust its like opening a whole can of worms.....tin worms lol Link to comment Share on other sites More sharing options...
escortlew Posted September 11, 2013 Share Posted September 11, 2013 Once again a fantastic update Gary!!! Link to comment Share on other sites More sharing options...
blacksofstichill Posted September 12, 2013 Author Share Posted September 12, 2013 cracking updates, mate, and a good job, bloody hell you got some rust issues there nice to see this coming along though, keep up the good work:thumb: Cheers! Some pretty big rust issues right enough but luckily there was still some solid metal left to weld to. Think the repair bill will be a bit of a surprise Good work though. As soon as you look for rust its like opening a whole can of worms.....tin worms lol Thanks, yeah, the deeper you dig the worse it gets but at least it will be solid when it's done. Once again a fantastic update Gary!!! Cheers Lew! Moving further back and onto the next hole now, this area is up from the end of the inner sill and really the whole of this area was rotten as was the inner rear wheel arch at the bottom - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0798.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0799.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0800.jpg First repair plate made - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0801.jpg And tacked into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0802.jpg At this point my Camera Batteries died but I had to crack on with the work that day, so my next photo is taken the following morning, the inner rear wheel arch was repaired at the bottom, there's new metal welded in basically right around where my finger is - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0803.jpg Repair plate made for the last bit of the underside of this area - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0804.jpg And welded into place, lapping my previous plate below it and tied in to the plates on the inner wheel arch - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0805.jpg Moving further back again, this is the split in the chassis where a previous plate had been welded to the mounting bracket, the metal is all solis, it just needs a plate over the split - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0806.jpg The large weld to the left has to stay as it is, it is the edge of a previous plate welded up the inside edge of the chasis leg and the weld is right next to the tank - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0807.jpg Repair plate made - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0808.jpg And welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0809.jpg Looking from the rear axle forwards you can see the extent of what has been repaired, the entire rear end of the inner sill and the front end of the chassis leg have been reconstructed in new metal - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0810.jpg No rest for the wicked, here is the chassis leg just behind the shocker after some poking with a screwdriver, not pretty - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0811.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0812.jpg At this point the Clarke Welder I'd been using decided to die, I think the sight of the chassis legs were just too much for it, it hadn't been producing a "nice" weld without constant adjustment of the settings and it got to the stage it just wouldn't weld at all. So, I brought round my Dad's Murex MIG which I'm much happier using - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0813.jpg Not that you'll see a great deal of difference but I also re-welded some of the last seams I'd done, just to be on the safe side - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0814.jpg Getting back to the chassis leg, I cut out the rotten areas - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0815.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0816.jpg Despite the large hole this left me with, I was lucky that some previous plating on the Chassis had been done well and with good metal so it gave me something I could weld to safely, first repair section is just a small plate - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0817.jpg This was welded up the inside edge of the rail - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0818.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0819.jpg Second repair plate made - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0820.jpg This one is also for the inside edge, lapping my previous plate this one finishes off the insde edge of this area - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0821.jpg Third repair plate made - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0822.jpg This one tucks under my last plate and finishes off the bottom of this area - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0823.jpg I also welded it to the strong inner skin of the area where the subframe bolts up - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0824.jpg Fourth repair section made - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0825.jpg This was just a small plate welded to the underside of the brake hose bracket - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0826.jpg Link to comment Share on other sites More sharing options...
blacksofstichill Posted September 12, 2013 Author Share Posted September 12, 2013 Fifth and final repair section for this area made - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0827.jpg And welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0828.jpg With this plate welded in, that's all of this hole replaced with new metal - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0829.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0830.jpg Just back from this area I found a thin bit of chassis which I easily made a small hole in, this is all good strong metal but I think it has been ground very thin in that one area when a previous weld had been ground back - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0831.jpg Repair plate made - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0832.jpg And welded into place, I made the plate cover a larger area than the hole in case other parts around there were equaly thin - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0833.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0834.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0835.jpg Welds ground back - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0836.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0837.jpg Further back on the rail there was another small hole - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0838.jpg I found that the metal was very solid around that area and the hole was still quite small even after some poking with a screwdriver and some grinding, it's hard to photograpth this area with the subframe in the way - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0839.jpg I decided that instead of making a small plate just for that area I'd make a plate to go the full length of the inside edge of that area - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0840.jpg Welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0841.jpg Looking underneath on the rest of the drivers side the only other dodgy area is a small bit fof rust in the rear footwell, this will be left until later when I have the full interior out though and will be an easy part to repair - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0842.jpg Link to comment Share on other sites More sharing options...
blacksofstichill Posted September 12, 2013 Author Share Posted September 12, 2013 With the drivers side chassis leg all sorted I removed the back bumper to see what was lurking beneath it, the panel here had split and was very rusty - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0843.jpg As you can see, it was so weak it easily pulled back by hand - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0844.jpg This area is double skinned, the inner and outer rear quarters are joined along the bottom edge here but there is a gap between them, albeit very small. So, to start with I cut off the rusty area of outer skin - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0845.jpg With that revealing more rust on the inner skin, I also cut the inner skin out too - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0846.jpg The corner of the area where the vent flap fits in was also rotten with a hole through to the inside of the boot - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0847.jpg To get myself started here I made a small repair plate to replace the missing flange near the bottom of the vent flap hole - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0848.jpg Welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0849.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0850.jpg Next up I made another small repair plate to fill in some of the missing area below the vent flap hole - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0851.jpg Welded into place, there are still gaps around it but my other plates fitted on the outer skin later on will sort that out - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0852.jpg Rather than just repair this area as a single skin and seal the two halves further back in the rear quarter I repaired both the inner and outer skins individually, starting with this panel for the inner skin - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0853.jpg Welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0854.jpg Then I made an infill piece to make up the gap - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0855.jpg Welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0856.jpg Looking from inside the arch, I still have it all to weld in there and areas to clean back but you can see how and where my plates have been fitted - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0857.jpg Next I made a panel to start replacing the outer skin - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0858.jpg Welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0859.jpg Welds dressed back - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0860.jpg Repair panel made for the top edge of the outer skin - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0861.jpg And welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0862.jpg Infill piece made which will complete the outer skin - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0863.jpg And welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0864.jpg Welds dressed back, if this was a panel which was on the outer bodywork you could carry out a similar repair but joggle/step back the edges of the repair plates so that the outer face sits flush with the existing panel rather than above or behind it as it does here - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0865.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0866.jpg Link to comment Share on other sites More sharing options...
scottybo Posted September 12, 2013 Share Posted September 12, 2013 entire cars gna be made of weld soon Link to comment Share on other sites More sharing options...
scottg17 Posted September 13, 2013 Share Posted September 13, 2013 Looks as bad as my GTI did..... I nearly fainted at the sight of the amount of welding it needed and ended up stripping it... Great to see you are sticking with it Link to comment Share on other sites More sharing options...
blacksofstichill Posted September 19, 2013 Author Share Posted September 19, 2013 entire cars gna be made of weld soon Oh Yes, and there's more to come yet! Looks as bad as my GTI did..... I nearly fainted at the sight of the amount of welding it needed and ended up stripping it... Great to see you are sticking with it Cheers! It needed a lot more welding than was anticipated but at least we know it's solid once it's done. I looked further back and found the edges of the vent flap hole crumbling away in some areas - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0867.jpg So I cut the rotten bits out, the shape of this panel doesn't make it easy to repair - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0868.jpg First repair panel made - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0869.jpg And welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0870.jpg Second repair panel made - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0871.jpg And welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0872.jpg With the welds roughly ground back you can see I still have the awkward little corner still to do - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0873.jpg This is where it gets fiddly! Small plate made up to form the curved flange in the corner - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0874.jpg Welded onto my other repair sections on either side - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0875.jpg Another very small plate made, this one will make up the flat back face of the panel, welded abover the small curved piece - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0876.jpg Welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0877.jpg The last plate to make is one to form the outer radius in the corner - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0878.jpg With that welded into place, that's this area all solid again - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0879.jpg After some careful grinding these pieces which have been repaired really start to take shape - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0880.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0881.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0882.jpg Viewed from inside the boot - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0883.jpg Back onto the underside of the arch I was almost ready to clean and weld this area here - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0884.jpg Until I looked further up and saw this, the filler neck isn't attached to anything as the surrounding panel has rotted away, very common problem indeed - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0885.jpg Before I let myself loose on that I primed and seam sealed some of the repairs I had done earlier, starting with the outer sill - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0886.jpg Then the inner arch at the end of the sill - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0887.jpg Chassis leg behind the shocker - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0888.jpg Inner Sill and front of the rear chassis leg - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0889.jpg Underside of Chassis leg at shocker - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0890.jpg Inner side of chassis leg toward the rear of the car - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0891.jpg Link to comment Share on other sites More sharing options...
escortlew Posted September 19, 2013 Share Posted September 19, 2013 Once again Gary - epic - a lot of work time and effort - look forward too the final piece of art! Link to comment Share on other sites More sharing options...
