lee grout Posted September 19, 2013 Share Posted September 19, 2013 You must have shares in that seam sealer Nice work on the vent into the boot. Link to comment Share on other sites More sharing options...
NielsF1 Posted September 19, 2013 Share Posted September 19, 2013 Wow, glad you're solving the rust issue...! Well done! Link to comment Share on other sites More sharing options...
blacksofstichill Posted September 20, 2013 Author Share Posted September 20, 2013 Once again Gary - epic - a lot of work time and effort - look forward too the final piece of art! Cheers Lew! You must have shares in that seam sealer Nice work on the vent into the boot. Thanks, the vent hole was quite a fiddly bit to sort! You can't beat a bit of seam sealer! Wow, glad you're solving the rust issue...! Well done! Thanks, there's even more rust yet to come believe it or not! With all of that tidied up I pulled the filler pipe out of the way to see how bad the rust was here - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0892.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0893.jpg I ground out all of the rusty areas unti I was back to good clean metal, this is now a massive hole compared to what it should be - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0894.jpg Repair panel cut but not shaped yet, I used a holesaw to cut out the centre hole - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0895.jpg Can you see how this is going to work - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0896.jpg After a bit of cutting and folding I had the repair panel roughy the right shape for the job - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0897.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0898.jpg Welded into place from the outside - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0899.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0900.jpg And also fully welded from the inside too - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0901.jpg While I was in here I also seam welded the inside edges of my earlier repair panels - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0902.jpg That means that all of my repair panels on the rear quarter are fully seam welded inside and out - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0903.jpg Fixing hole drilled in the filler neck panel, the pipe isn't bolted in place here hence why it's not sitting centrally, you get the idea though - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0904.jpg With this corner now complete I primed and seam sealed it all inside and out - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0905.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0906.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0907.jpg The inside of the boot could do with another coat of sealer to smooth it out more after this coat has set - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0908.jpg All I use to make these repair panels is this electric shear to cut the sheet metal - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0909.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0910.jpg And this basic folder - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0911.jpg Obviously a hammer and an anvil are sometimes used too! moving on from the drivers side I started by checking out the boot floor and spare wheel well - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0912.jpg The spare wheel well had a lot of rust but no holes in it, so I started to clean off the surface rust to get a better idea of how solid it was - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0913.jpg The pitting of the rust was very deep and the remaining metal was very thin, although you can't see it in the photos there were lots of tiny holes also starting to appear - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0914.jpg Chipping off some of the scaley rust also led to more pinholes appearing and again, the metal was weak and thin - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0915.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0916.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0917.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0918.jpg Link to comment Share on other sites More sharing options...
sidrick Posted September 20, 2013 Share Posted September 20, 2013 That's some graft you're putting in! Nice updates. Any reason you/the owner didn just go for another shell? Link to comment Share on other sites More sharing options...
blacksofstichill Posted September 25, 2013 Author Share Posted September 25, 2013 That's some graft you're putting in! Nice updates. Any reason you/the owner didn just go for another shell? Thanks, some of it has been quite a challenge but I've enjoyed it! With hindsight, another shell would have been a good idea but it's finding one (particularly a 4x4 one) that isn't also going to need welding at a decent price that isn't so easy. That and the fact that the owner wanted a black one in particular (this one was painted black in his ownership) made it a bit more justifiable to use this one. Mind you, when you see some of the rest of the welding that is yet to come you'll think we are mad! Since it was like this all over the bottom of the well it meant there was no good metal left to do any localised plating and in any case it would mean that the areas not plated at this time would only end up having to be done in a year or so. So, without further ado I cut the bottom of the spare wheel well out - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0919.jpg I also cut out some areas of the side of the well which were also rusty and weak - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0920.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0921.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0922.jpg So this is what I was left with - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0923.jpg Starting with repairing the sides I cut a plate for the left hand side - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0924.jpg I then shaped it to roughly the curve of the bottom edge of the well - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0925.jpg Welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0926.jpg Welds dressed back - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0927.jpg On the right hand side there is a much larger area to plate on the side of the well but I start off with the mostly straight section first - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0928.jpg Welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0929.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0930.jpg Welds dressed back - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0931.jpg This is what I've got left to fill in on the right hand side - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0932.jpg Because it's all on a curve and over a large area I decided to make this up in 3 sections starting with the middle section - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0933.jpg Welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0934.jpg Next section made - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0935.jpg And welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0936.jpg Last section made - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0937.jpg And welded into place to complete that area - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0938.jpg Welds dressed back - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0939.jpg Since you can't buy a spare wheel well repair panel I have to make my own one up, rather than just make it flat right along the bottom I decided to make it recessed in the middle similar to what it was originally. This was partly so it woul look better but mostly to make it a stronger job So, I cut a round plate for the centre recess - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0940.jpg I then formed an angle right around the edges of it - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0941.jpg With it laid over the top of the original panel you get an idea of why I've shaped it in that way - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0942.jpg I then needed to make the outer circle to fit around the centre, since it is a large area I made it in two halves, here is the first half cut out - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0943.jpg And again, I formed an angle on the edge of this - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0944.jpg And then I welded the first half of my outer circle to the centre panel - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0945.jpg With that laid into place you can see how it will work - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0946.jpg Second half of the outer circle cut and formed - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0947.jpg And all welded together - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0948.jpg Link to comment Share on other sites More sharing options...
Hezz Posted September 27, 2013 Share Posted September 27, 2013 Did you think about making the spare wheel well big enough to fit a proper wheel rather than the 4x4 pram wheel ? Great work as always Link to comment Share on other sites More sharing options...
blacksofstichill Posted October 2, 2013 Author Share Posted October 2, 2013 Did you think about making the spare wheel well big enough to fit a proper wheel rather than the 4x4 pram wheel ? Great work as always Cheers! I didn't make the wheel well any bigger, I just replicated what was there but if I hadn't been able to save any of the original sides and bottom edge of the well I'd have probably made it bigger while I was at it. With the 2 panels side by side you can see the recess I've made in it is similar in size and depth - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0949.jpg Welds all dressed back on the underside before fitting - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0950.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0951.jpg And welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0952.jpg Welds dressed back - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0953.jpg Spare wheel retaining bracket cut off the original panel - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0954.jpg And welded onto the new one - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0955.jpg Looking at the rest of the boot floor, there were a couple of small holes and some areas of surface rust, none of these were very serious or big but they're best to be plated now while the metal was still good - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0956.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0957.jpg First area ground back - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0958.jpg Plate cut to suit - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0959.jpg And welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0960.jpg Second area ground back - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0961.jpg Plate cut to suit and welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0962.jpg Last area cleaned back - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0963.jpg Plate cut to suit - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0964.jpg Welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0965.jpg All welds dressed back - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0966.jpg Onto the seam sealing now, some of these areas will get a second coat tomorrow to smooth them out further at the seams, starting out with the underside of the spare wheel well - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0967.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0968.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0969.jpg The plated areas on the boot floor - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0970.jpg And finally inside the spare wheel well - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0971.jpg Link to comment Share on other sites More sharing options...
sidrick Posted October 2, 2013 Share Posted October 2, 2013 Quality graft as usual. Loving all the photos. Link to comment Share on other sites More sharing options...
blacksofstichill Posted October 3, 2013 Author Share Posted October 3, 2013 Thanks, there's still plenty of pics to come. With the spare wheel well sorted out I started looking at the passenger side of the boot floor, it had already been plated in the corner of the boot and at the bottom of the inner arch - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0972.jpg To be sure the plates were solid I cleaned them back and dressed the welds a bit too - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0973.jpg However, it wasn't all good news, I could see daylight inside the back quarter - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0974.jpg The hole comes through to the outside here - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0975.jpg There was masses of sealer on the inside of this area - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0976.jpg The hole is getting bigger - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0977.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0978.jpg Because this whole area is rotten where the bumper screws on I'll have to cut it off completely rather than plate in repair sections, so to be sure I make my repair panel the correct shape I'll make it all off the car, mark where it needs to go and fit it as one piece once the rotten area is cut off......so I started making this bit first - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0979.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0980.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0981.jpg Checking it for fit - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0982.jpg Onto the next bit - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0983.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0984.jpg Second section welded to the first piece and checked for fit on the car - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0985.jpg Onto the next piece of the puzzle - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0986.jpg You'll notice that there is a split in the rear quarter above the bumper line but my repair panel will not cover that part, this is intentional as if I repair any of the outer bodywork such as this it means that Olly basically has to get the car painted as soon as I'm finished with it. By keeping all of my repair sections out of site it means that no paintwork is needed immediately but whoever makes the bodywork repairs will have good clean metal below the bumper line to weld in small repair sections when the time comes - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0987.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0988.jpg Another piece - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0989.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0990.jpg Another trial fit and this time I mark on the body where the edges of my repair panel should go so I can line it up in the correct place once the rotten section is cut off - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0991.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0992.jpg Inner arch area cleaned back - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0993.jpg Rotten outer section cut off - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0994.jpg New section welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0995.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0996.jpg Welds dressed back - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0997.jpg Link to comment Share on other sites More sharing options...
blacksofstichill Posted October 11, 2013 Author Share Posted October 11, 2013 Viewed from the inside of the arch you can see where I need to fill in the gaps with new metal - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0998.jpg Repair plate cut - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/0999.jpg And welded into place, I also rewelded an existing plate along the bottom edge as it was loose - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01000.jpg Another plate cut - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01001.jpg And welded into place - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01002.jpg Priming and seam sealing this area inside and out now - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01003.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01004.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01005.jpg Looking further forward at the rest of the inner arch more holes were revealed - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01006.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01007.jpg Before I tackled those I resealed the existing plates inside the boot - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01008.jpg Inner arch holes viewed from inside the passenger back quarter - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01009.jpg Rotten areas cut right out - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01010.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01011.jpg Instead of struggling to make this repair all with one plate I did it in 3 sections, first one here - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01012.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01013.jpg Second one - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01014.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01015.jpg Third one completes the repair in this area - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01016.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01017.jpg There was also some rot at the bottom of the inner arch where it meets the inner sill - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01018.jpg asessing the damage, this area will be left until the inner and outer sills are looked at- http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01019.jpg Moving onto the rear chassis rail, more rust is evident with splits showing in the leg - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01020.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01021.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01022.jpg Some of the loose rust chipped out of the way in the first area to be repaired - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01023.jpg Surrounding area ground back to good metal, because the inner section of the chassis is sound I'll be able to weld my outer plates to it to add extra strength to the job - http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01024.jpg http://blackengineering.co.uk/images/Doctor-Evil-RS2000-Turbo-Engine-Rebuild/01025.jpg Link to comment Share on other sites More sharing options...
lee grout Posted October 11, 2013 Share Posted October 11, 2013 Well............................... 1: Great work as ALWAYS. 2: Surely it would of been cheaper for the guy to find a clean shell for a couple hundred quid!? I bet your well into that sort of figure with repairs and I bet there's still plenty to go! Link to comment Share on other sites More sharing options...
Naylor2006 Posted October 13, 2013 Share Posted October 13, 2013 Well............................... 1: Great work as ALWAYS. 2: Surely it would of been cheaper for the guy to find a clean shell for a couple hundred quid!? I bet your well into that sort of figure with repairs and I bet there's still plenty to go! Top top work, love following this. Its a 4x4 isnt it, there would be limited numbers and at a premium price. Link to comment Share on other sites More sharing options...
JC Posted October 13, 2013 Share Posted October 13, 2013 A really good read, good work, and loving all the pics Link to comment Share on other sites More sharing options...
sidrick Posted October 16, 2013 Share Posted October 16, 2013 5 days without an update? Unacceptable! I assume you're too busy cutting and welding though Link to comment Share on other sites More sharing options...
scottybo Posted October 16, 2013 Share Posted October 16, 2013 5 days without an update? Unacceptable! I assume you're too busy cutting and welding though i doubt there will be much original metal left by the end! Link to comment Share on other sites More sharing options...
