scottybo Posted August 24, 2013 Share Posted August 24, 2013 fcuker fell off yesterday! whats the best way of getting it stuck back on. ive tried various glues as well as a 'mirror glue kit' from halfrauds.....whats a load of bollox that was lol any advice? Link to comment Share on other sites More sharing options...
JC Posted August 24, 2013 Share Posted August 24, 2013 the double sides stickers that are designed for fitting rear view mirrors? Link to comment Share on other sites More sharing options...
shawdreamer Posted August 25, 2013 Share Posted August 25, 2013 tigerseal that fecker back on............dont expect to be able to remove it again without destroying the window though. Link to comment Share on other sites More sharing options...
scottybo Posted August 25, 2013 Author Share Posted August 25, 2013 the double sides stickers that are designed for fitting rear view mirrors? tried...fell straight off after 1 bump in the road tigerseal that fecker back on............dont expect to be able to remove it again without destroying the window though. how long does it take to dry. my atms are beginning to ache from holdin it against the windscreen lol Link to comment Share on other sites More sharing options...
SLEEMAN Posted August 25, 2013 Share Posted August 25, 2013 You have to remove all the glue residue off first and maybe a quick degrease on both surfaces then the sticker should work Link to comment Share on other sites More sharing options...
Craig855S Posted August 25, 2013 Share Posted August 25, 2013 double sided foam things work fine so long as you remove all residue well Link to comment Share on other sites More sharing options...
scottybo Posted August 25, 2013 Author Share Posted August 25, 2013 double sided foam things work fine so long as you remove all residue well until u want to adjust the mirror. then the whole things comes off Link to comment Share on other sites More sharing options...
Craig855S Posted August 25, 2013 Share Posted August 25, 2013 double sided foam things work fine so long as you remove all residue well until u want to adjust the mirror. then the whole things comes off clean and lubricate the ball fitting, i remember one of my escorts ball was stiff as hell and i also ripped that one off again and again but the others were fine, and all other cars have owned have been easy to move, cheap and nasty ford mirrors.. in fact, i think i fitted a different mirror to my mk6 due to the standard escort one being so awful Link to comment Share on other sites More sharing options...
scottybo Posted August 25, 2013 Author Share Posted August 25, 2013 mines always been nice n smooth man Link to comment Share on other sites More sharing options...
dalelc16 Posted August 25, 2013 Share Posted August 25, 2013 The best tio I think is to use the foam mirror pads, make sure the mirror part is clean with no grease or glue etc, give it a little.make sure you clean dust off.stick pad to mirror,give it a good rub down.Then the black part on the glass give that a good clean. No glue ect make sure its flat.Stick to your window. Link to comment Share on other sites More sharing options...
scottybo Posted August 25, 2013 Author Share Posted August 25, 2013 ill try tiger sealing it like shaw suggested....cant hurt to try ive already wasted 20 quid trying to stick it back on Link to comment Share on other sites More sharing options...
tomsy Posted August 26, 2013 Share Posted August 26, 2013 Give everything your sticking a good wipe with white spirit the cleaner the surfaces the better the results wait for the white spirit to dry off first though. Link to comment Share on other sites More sharing options...
scottybo Posted August 30, 2013 Author Share Posted August 30, 2013 still cant get the fcuker on! Link to comment Share on other sites More sharing options...
tomsy Posted August 30, 2013 Share Posted August 30, 2013 Get one with a suction pad sorted Link to comment Share on other sites More sharing options...
SLEEMAN Posted August 31, 2013 Share Posted August 31, 2013 In that case then get a newer rear view mirror then. Probably is damaged Link to comment Share on other sites More sharing options...
