Ex-Finesse Posted February 7, 2006 Author Share Posted February 7, 2006 If everyone would like to reminisce.... Mike has never seen a Ford broken down on the side of the road Now he has - his own PS> Did you find the rubber glove? Link to comment Share on other sites More sharing options...
Benjy C Posted February 7, 2006 Share Posted February 7, 2006 sse' date='Feb 7 2006, 12:15 AM' post='662791'] PS> Did you find the rubber glove? :roll: I think he did lmao Link to comment Share on other sites More sharing options...
silvershaddow Posted February 7, 2006 Share Posted February 7, 2006 So does a 2.0 run on a 1.6 ECM or do you need a 2.0 map? Link to comment Share on other sites More sharing options...
Ex-Finesse Posted February 7, 2006 Author Share Posted February 7, 2006 I know from when the 2.0 engine went in the black one that it runs ok on the 1.6 ecu and MAF, although idle is fast for a while as so much more air is flowing through the MAF than normal for those revs, due to the bigger capacity. Link to comment Share on other sites More sharing options...
silvershaddow Posted February 7, 2006 Share Posted February 7, 2006 Yeah sounds about right, was just wondering about a 2.0 conversion myself in a few years. Anyone ever bother using TuneBoy type kit that lets you remap your ECU without changing it by just plugging in a secondary loom? Link to comment Share on other sites More sharing options...
Ex-Finesse Posted February 7, 2006 Author Share Posted February 7, 2006 Sounds like an alternative.... but why would you want to replace a standard ford unit with a home brewed effort? EEC-IV and EEC-V are incredibly advanced ecus Link to comment Share on other sites More sharing options...
silvershaddow Posted February 7, 2006 Share Posted February 7, 2006 Was just wondering how you remapped a standard ECU. On the Daytona we have to either change the ECU or stick an overlay box over the top to change the values by a set amount. The latters pretty crap but lets you use the standard bike ECU which is cheaper. We've got a datalogger dash which helps too, lets you monitor the lamba and a variety of sensors after a run. What kinda stuff can you change in a standard ECU? Have never really thought about modifying to this level so forgive me if they're stupid questions!! :-) Link to comment Share on other sites More sharing options...
Craig855S Posted February 9, 2006 Share Posted February 9, 2006 whats all this fisting malarky about???? and what is the correct way to remove driveshafts,as im doin it on sunday,what does the gearbox end of a removed d/shaft look like????? is it 3 splines?? or do u need to take that spinny bit off too? Link to comment Share on other sites More sharing options...
Ex-Finesse Posted February 9, 2006 Author Share Posted February 9, 2006 Fisting - we dunno how it started, but it has and that's that! The way we've done the driveshafts is to drop the ball joint from the bottom of the suspension carrier, undo the nut tightening around the bottom of the shock and free the suspension carrier from the bottom of the shock. You may also want to remove the brake pipe, clamping it first. This allows the whole driveshaft / suspension carrier / hub / brake setup to be removed as one! Driveshafts, you ideally want a crowbar. If not, 2 large flat head screwdrivers teased into the gap will see them out. Have one person holding the hub / brake end Link to comment Share on other sites More sharing options...
Craig855S Posted February 10, 2006 Share Posted February 10, 2006 just looked on meatspin since u lot were raving about it. OMG,bunch of pervs Link to comment Share on other sites More sharing options...
bluliz Posted February 10, 2006 Share Posted February 10, 2006 Have Rob holding the hub / brake end Link to comment Share on other sites More sharing options...
danposs86 Posted February 11, 2006 Share Posted February 11, 2006 Have Rob holding the hub / brake end Now now, less of the "just smilies" Link to comment Share on other sites More sharing options...
Muzz Posted February 11, 2006 Share Posted February 11, 2006 (edited) Have Rob holding the hub / brake end Now now, less of the "just smilies" Are you blind or just stupid? As there is clearly a modified quote in their which has been highlighted, therefore it is not a single smiley post . You got it in and running yet Ralph? Edited February 11, 2006 by Muzz Link to comment Share on other sites More sharing options...
Matthew H Posted February 11, 2006 Share Posted February 11, 2006 (edited) is the engine actually in yet? or is it a work in progress social event Edited February 11, 2006 by Matthew H Link to comment Share on other sites More sharing options...
danposs86 Posted February 11, 2006 Share Posted February 11, 2006 Have Rob holding the hub / brake end Now now, less of the "just smilies" Are you blind or just stupid? As there is clearly a modified quote in their which has been highlighted, therefore it is not a single smiley post . You got it in and running yet Ralph? Yes true smart @rse, but they werent his words, his contribution was just a smilie Link to comment Share on other sites More sharing options...
